WMF1500S brew problem
WMF1500s problem
77a77a
18 Apr, 19:50
Mitgliedsnummer.: 91600
Hi, I have a WMF1500S that has an issue. The espresso dispensing is ok at first but after a couple of seconds it turns watery resulting in a weak coffee. Has anyone experienced this before or have any advice to check? Is there a way to view any sort of view pressure?
I have tried increasing the recipe 'quality' factor which in turn increases the wet and dry pressing of the grounds. this does result in a more strong coffee but will give the error of low brew flow (Error 9480). I think the machine has only done 30,000 brew cycles so burrs should be ok? I have tried swapping the brew unit but there is no change.
Many thanks.
